x-y graphing problems
I'm having a problem...
 X-Y graphing
    - The problem seems that as i'm trying to pass the data outside the loop the data is not showing up
    - Is the execution of this passing method not good?
       - I have tried using shift registers and that doesn't seem to work either.
          - I'm stuck :-(.
(3,481 Views)
Hi flyn,
what are you trying to do?
Please have a look into the changed vi, there are some very 'strange' things going on in your code 🙂 I made some small changes and notes in the diagram.
(3,478 Views)
okay I made some of the suggested changes, I understand exactly what you were saying, mental gubber it seems.  However, the problem still exsists.  The data is not being passed outside the loop.  Not sure why though.
(3,474 Views)
Either put the graph inside the while loop or right click on the output tunnels and select enable indexing.
Joe.
"NOTHING IS EVER EASY"
(3,463 Views)
i tried it with the indexing and that doesn't seem to work.  If I put it inside the while loop it resets the graph everytime and basically I want to keep the values in the graph so i can see it changing.
(3,456 Views)
Use shift registers with the graph inside the loop see picture.
Message Edited by AndrewAlford on 11-07-2006 01:29 PM
Andrew Alford
Production Test Engineering Technologist
Sustainable Energy Technologies
www.sustainableenergy.com
(3,437 Views)
