x y graphs remember old values
I have a XY Graph and when i run my vi Graph shows right graph what i want.
Problem comes when i run it again. Old values appears to graph and new values
start draw onto same graphs and result is mess.
I initial graph zero values begining of vi and reset it but still same problem.
What is wrong ?
-HeVi-
(3,818 Views)
Post a simplified version of your vi illustrating the problem, and somebody will help you.
CC
Chilly Charly    (aka CC)
(3,814 Views)
Problem solved (one array init missing).
Thank You
(3,812 Views)
Hello
(3,725 Views)
Hello..
I have the same problem. I can`t seem to reset the xy graph. I have an "write to mesurment file" in parallel to the the xy graph and it just keeps adding the data whenever I run the program again.
What exactly did you do to reset the old values?????
Tommy
(3,724 Views)
Hi !
It's been while when i was here and this case... one year .... i dont belive that i can find my solution, but if i remeber right
it was only to put one array initialization to right place / right side of for or while loop !
(IF i found it i write here forum)
BR -HeVi-
(3,718 Views)
