x410 device FPGA not connected
"https://www.ni.com/docs/ko-KR/bundle/usrp-x410-getting-started/page/getting-started.html" I followed the Installing the Software section from the above address and used the NI-USRP Configuration Utility. I uploaded the image file (X410ReferenceFpga_4ch_4spc.lvbitx). Afterwards, I tried to check if it was connected to the FPGA through NI MAX, but it did not connect. And I'm experiencing a problem where the USRP device resets when I turn it off and on. What should I do to solve this problem?
Message 1 of 1
(583 Views)
