xception occured in Microsoft Access Database Engine: The field is too small to accept the amount of data you attempted to add.
hi
i try to save a path into a table of an access database but an error occur:
"Exception occured in Microsoft Access Database Engine: The field is too small to accept the amount of data you attempted to add. Try inserting or pasting less data. in NI_Database_API.lvlib:Rec Create - Command.vi->NI_Database_API.lvlib:Cmd Execute.vi->NI_Database_API.lvlib:DB Tools Insert Data.vi->projet total.vi"
i attached a jpeg image of a portion of the code and the code but it will not run because the database is not attached,
any help plz?
(3,050 Views)
Accepted by topic author iman
ok
i solve the problem.i rezise the colomn size
thanks
(3,045 Views)
