xcontrol frontpanel access
Hi all,
I need to publish a front panel which developed using xcontrol facade vi. The success factor is that iam able to access that in the web.
But the problem is that, the frontpanel not looks as similar in the application. The facade vi controls are getting misalignment.
What is the problem..Any Idea..Please...
(3,215 Views)
No way to solve this issue? :mansad:
(3,182 Views)
If you can able to edit the front panel that you want to access through net then group them all and lock it then try accessing it.. just a try..
Smiley Wink
(3,175 Views)
Hi, anand thank for the reply, but i am loading the controls dynamically in a subpanel using VI server ..
(3,156 Views)
