xcontrol tutorial
I am trying to work my way through the tutorial Creating New Front Panel Objects with LabVIEW XControls.
It seems to leave out some steps. I'm having trouble understanding what I am suppose to do.
1.) in the Facade ability section, am I suppose to replace the Data In and Data Out controls with the Slide control
and add a boolean checkbox?
2.) what is the c --> f  VI that is shown in the Exec State Change section?
where am I to get that?
(4,855 Views)
Hi:
The Facade VI has three inputs and three ouput, as show in the block diagram, and ALSO has an slider an a checkbox. The Data In and Data Out controls are not shown in the Front Panel Images.
The C-->F and F-->C VI's shown in the screenshots are VI's that convert from Celsius Degrees to Farenheit degrees and viceversa. Quite easy  Smiley Wink
Hope this Helps.
Robst - CLD
Using LabVIEW since version 7.0
(4,849 Views)
thanks.
1.)  what about the thermometer?
2.)  do I have to manually add the "Thermometer":Value Change case?
(4,836 Views)
Yes, the Thermometer must also be added manually, as U did with the slider and the checkbox.
Regards.
Robst - CLD
(4,831 Views)
