xilinx option not available :::
hi
i am using labview 2012 fpga with sparta 3e device
i note that xilinx option
is it not supprorted or what???
regardsc.png not availabe
hi ?Q>
Message 1 of 10
(4,178 Views)
Hello mangood,
Do you have the actual SPARTAN-3E XUP Starter Kit, or just a random Spartan 3E FPGA card?
Does an FPGA VI compiles correctly on that target?
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
Message 2 of 10
(4,155 Views)
Hey mangood,
As you can see from the target properties window (right-click the Spartan3e target, then select properties), it does not support the Xilinx configurations options that NI supplied targets do.
Cheers!
TJ G
Message 3 of 10
(4,153 Views)
@T-REX$ wrote:
Hey mangood,
oh god why this happen ???
its just a option
we pay alot of money
oh god
hi ?Q>
Message 4 of 10
(4,144 Views)
@REDS wrote:
Hello mangood,
yes its spartan 3e 500 exactly
hi ?Q>
Message 5 of 10
(4,143 Views)
What exactly is it that you need to configure on your compilation?
Message 6 of 10
(4,130 Views)
Hello mangood,
It doesn’t surprise me that much that the Xilinx compiler options menu is unavailable. Remember that this is an educational kit. This option only allows you to modify how Xilinx optimizes the FPGA compilation process for timing, area, etc.
Daniel REDS
RF Systems Engineer
Help us grow.
Message 7 of 10
(4,116 Views)
i need it to change some optimization method like reduce area and reduce frequency
hi ?Q>
Message 8 of 10
(4,106 Views)
@REDS wrote:
Hello mangood,
i know its an educational kit but some option must avaliable like this option
regards
hi ?Q>
Message 9 of 10
(4,105 Views)
regards
"must" is a very strong word for an academic target that is meant for simpler projects to introduce students to digital design concerns. If you are truly creating designs for coursework that push the size limits as the configuration stands on the target you are beginning to move outside of the realm that these boards were intended to service
Message 10 of 10
(4,098 Views)
