xml-file doesnt change at first time
my problem is that the vi doenst read texml file correct. when you press the folder-button and choose one xml file i had to choose it two times. why?
when i choose another file the choosen file will displayed correctly when i choose it a second time.
so i had to choose the file two times.
(2,502 Views)
you have to put the path control inside the event structure!
regards,
Thomas Sandrisser
(2,502 Views)
