xml to Cluster & cluster to xml
Hi everyone.
I developed "Cluster to xml" and "xml to cluster" converter.I hope more people benefit.
Download Project
http://www.2shared.com/file/dDpYJfMy/Xml_Cluster_Folder.html
Best Regards.
Himmet GENCER
Himmet GENCER
Software Development Coordinator at TDG
himmetgencer@gmail.com
View Himmet Gencer's profile on LinkedIn
View on Instagram
Message 1 of 12
(4,895 Views)
Himmet GENCER
View on Instagram
Message 2 of 12
(4,882 Views)
That looks interesting, but I am suspicious of downloading from sites I don't know.
Could you post a zip?
Or, post images of the code please ?
Curious,
Ben
Message 3 of 12
(4,873 Views)
How is this different from JKI's Easy XML Toolkit? I am also leery of downloading from unknown sites. If you're asking for critique, please upload your VI(s) here.
Message 4 of 12
(4,866 Views)
 JKI's Easy XML Toolkit is not free.30 days evaulate mode and not open source
Himmet GENCER
View on Instagram
Message 5 of 12
(4,858 Views)
download link
https://decibel.ni.com/content/docs/DOC-19060
Himmet GENCER
View on Instagram
Message 6 of 12
(4,857 Views)
Ni Labview forum no permission to zip rar etc. file?
Himmet GENCER
View on Instagram
Message 7 of 12
(4,853 Views)
I was actually referring to implementation, not license.
You can upload ZIP files just fine - I've done it many times. Maybe you just encountered a server hiccup.
As for the code: this appears to be a fairly simplistic wrapper around an OpenG VI to perform a single case of a cluster to XML. It's quite limited (e.g., doesn't handle arrays, or sub-clusters), so comparing it JKI's Easy XML Toolkit is not a fair comparison, to say the least. As an example VI, understanding its limitations, it's suitable, though you can simplify the for-loop considerably. You can replace all of the code inside the for-loop with a single Format Into String function.
Message 8 of 12
(4,831 Views)
Why not just use the built-in functions?
Message 9 of 12
(4,825 Views)
Because those functions use the LabVIEW schema, not a schema that is better suited for, well, just about everything else.
Message 10 of 12
(4,820 Views)
