xnet and shared variable
hello,
I've got some trouble :
i've many application (.exe) , and i add some shared variable into.
Some work correctly but 2 others which use X-NET  doesn't work.
It send this error (-1074384750  XNET Read (Frame CAN).vi:2 ,  it's the first X-NET Vi in the soft.
All drivers are correctly update, and i try with labview 8.6 and labview 2011.
When i suppress shared variable and librairy, it works .
have you an idea ?
thanks
(2,886 Views)
