xy chart with no time axis--new to labview
I have a very simple question which I cannot figure out, despite reading everything about it on the forums.  I have data inputs from two different sources occuring at the same time.  I would like to plot the amplitude of one source against the amplitude of the other in real time, but not with respect to time.
I tried using the xy chart and passing the things to arrays first, but it didn't work, so i reverted back...I have a while loop going in the background.
If anyone could help, I would really really appreciate it...also, if there is an easy way to do things, that would be best, since I am new to labview and do not understand many of the advanced features.
Mike
(2,985 Views)
Hi inkljlkj (is that random or what?).
Fortunately your solution is very easy.  Using the diagram that you have posted as a jpeg, right-click on the Build X-Y Graph vi and select 'Properties'.  You will only have one option: clear the check box.  This allows the VI to accumulate each data point you send to the graph.  If you want to make a button that flushes the data and starts over, you will need to do something a bit more complicated, otherwise, the graph will just continue to accumulate a bigger and bigger plot until it bogs down.  I've built some cool-looking 'tracer' plots that accumulate only the last, say, 50 points and plots them in real-time, allowing one to see the dynamic history of your data.
Good luck,
Matt
(2,969 Views)
Im confused as to your issue. Is it that the data isnt plotting and you are getting a single point on your XY? Or are you asking why time isn't being plotted on the X-axis?
The first problem was answered by MatthewDC above.
In your program you are plotting amplitude vs. amplitude... I would find this a very difficult way to compare two amplitudes. personally.
EDIT: nevermind... after I read your post a couple more times i understand that is the functionality you are looking for.
Message Edited by MJBrehm on 09-14-2006 03:19 PM
(2,961 Views)
Thank you so much for the help.  It works now!!
Smiley Happy
(2,946 Views)
