xy graph automatically moves down
Hi,,,, I've got a problem. I have the XY graph and I would like the graph automatically moves down while running program. If u guys have ever seen the monitor of a roller testbench, Im working with a guidance system for a driver, using LabVIEW to create speed profile graph. I've manually done the examples by panning and PrtSc them as attached files.
 Any idea?
Mannie
(3,824 Views)
Mannie,
You may be able to use the xy graph properties nodes to accomplish this.  Just change the Y Scale -> Range -> Minimum and Maximum property nodes of your xy graph to get the effect you want.  SS
(3,813 Views)
If I understand what you want to do, all you need to do really is switch the X and Y axes. Here's a quick example.
___________________
Try to take over the world!
(3,810 Views)
