xy graph in PDA module does not plot points or update
The XY Graph for PDA does not plot points or update. Input data is simple cluster of floating point data (x,y)in while structure. The axes scale properly with Configure PDA XY Scales.vi. Cursor legend also OK. Checked line and point attributes-OK. Running 7.0F1 and pocketPC2003. Please help.
(3,161 Views)
Garret,
Can you attach the VI so that we can see it? If you think it is a bug in the toolkit, rather than a programing thing I would suggest sending an e-mail to NI. In addition are you using eVT 3 or 4 or both?
(3,161 Views)
