xy graph look different after Stop
my xy graph looks in the .jpg and after stopping the program different...
check atachment...
I probably need some prooperty nodes... but I cannot figure is out, which one..
thanks
Ugur
(2,803 Views)
I've never seen a change in the graphs as a sole result of stopping a VI.
  • How do you stop the VI? (abort button, normal via a stop button, etc.)
  • Is there any extra code that executes at the end?
  • Is you graph axis set to "loose fit"?
What is your LabVIEW version? Do you have a simple VI that demonstrates the problem. Please attach it. 🙂
(And what's up with that attachment. You have a word document containing images of your VI front panel embedded in an excel sheet. Very convoluted. ;))
(2,794 Views)
morning,
I am trying to crate an easy example. But easy code does not have this problem.
But what I have found is: it adds the addtional time to the beginning and to the end to have proper divisons. see attachement.
(the only code which has to be done after taking the jpg image, it is to complete the excel log file add the jpg into Excel)
(2,770 Views)
I agree with altenbach. There's just not enough information to go on. You didn't answer the question as to which LabVIEW version you're using.
Based solely on the screenshots, there seems to be more than what you say going on after you stop. For instance, the "before" picture doesn't have a path indicator or the big long STOP button, or the elapsed time indicator or the Boolean push button. The "after" does. Where did they come from?
One thing you may want to try is to set the Window Appearance to "Default". Again, based solely on the screenshot, it looks like when the VI is running you're turning off the scroll bars. Perhaps you also have a run-time menu? Or, are you turning off the menubar as well?
Message Edited by smercurio_fc on 01-10-2008 09:12 AM
(2,758 Views)
