xy graph plot values
I have an xy graph with three plots. I need a property node or something (I couldn't find what I need) that I can give a value for X and it will return a value for Y. I don't know the value of Y before hand.
Basically, I need the value of Y for any given value of X.
Thanks!
(2,905 Views)
Perhaps you want the Interpolate function  https://forums.ni.com/t5/LabVIEW/xy-graph-plot-values/td-p/1678942
Since you have the data that made the XY graphs, you can use array data to find the corresponding Y.  You may also need the Threshold 1-D array function in the event your X data falls between actual values you have in your X array.
(2,897 Views)
Wayne,
Since you only need the "value of Y for any given value of X" I would recommend to just SEARCH 1D ARRAY for your X value (which will output the indexed value for X). Then just feed that indexed value to the input of INDEX ARRAY for your Y 1D array. You can control the iterations of this operation by having your # of plots control your loop executions.
Chazzzmd
(2,896 Views)
