xy graph text
hi again
i hv also tested chk graph2.vi  on my C2D  PC  which causing me 4 - 6 %
but i have to  distribute the application and i can not force user to use C2Ds
what would be the best way to display text with anticlockwise orientation
thanks to be with me
Message 11 of 13
(548 Views)
Hi manufacturer,
make the graph transparent and put a picture indicator behind it. That way the redraw of the picture can be minimized.
See if this helps, as now LabVIEW has to handle two overlapping indicators...
Message 12 of 13
(545 Views)
hi
making  the graph transparent and putting  a picture indicator behind it
was'nt also working , whenever graph control refreshes picture control does the same
and use CPU resource ,
if i do not put a picture in any use the graph control works without hassel
if i put any other picture even with higher resolutions it works with 10% of  that RT text picture
can we draw text throuh other method
Message 13 of 13
(527 Views)
