xy-graph with continous displaying
I have wrote a simple program (attached) to display two measured value pairs which then are displayed in an xy-graph. The two values are related to each other in the x and y axis. The problem now is that the program shows only the actual value as a point in the graph.
My task is to create a program which shows and displays all the measured values as long as the "run" button is pressed continuously. Can someone give me an example? Many thanks
(2,994 Views)
You need to use shift registers in your while loop.
(2,994 Views)
In a previous post, you were refered to the example Variable-Time Chart XY.vi. This example has shipped with LabVIEW for quite a long time. Select Find Examples under the Help menu, click the search tab, and enter xy for the keyword.
(2,994 Views)
Many thanks Dennis, thats was the solution!!
(2,994 Views)
