xy-graph x-scale changes position when togle visible
I'm using a cesond x-scale on en xy-graph (one on top, one on the bottom) when changing the atribute ->x-scale visibel, and back, then the position of the scale changes and is suddenly inside the actual graph area instead of above it (the attached file shows this behaviour - but only once! - after the first time making it visible again it stays at the wrong place...)
(2,550 Views)
The scale position changes due to plot area change. Put the following line into labview.ini file:
EnableAutoScales=False
However, doing this will not allow you to create new multiple scales. In this case, just change it to True. After adding/removeing scales, set it back to False.
Or you can try the method illustrated in the attached image.
Joe
(2,550 Views)
