xy graph
Can I know why the attached file..is not giving the exact values in graph...please reply
(2,536 Views)
For me it gives the exact values. What else do you expect?
There are two points with the same random y value on the graph (which you call x in the formula node).
each has a different x value according to the formula.
Please explain what you are trying to do...
(2,525 Views)
