y intercept
How can i find the intercept after joining 2 points and show the equations ?
(3,365 Views)
That's a basic math problem.
Delta Y/ Delta X will give you the slope of the two points.  Then apply that to a y=mx+b formula for one of the points and you'll have the y-intercept b.
(3,364 Views)
wt i means is using matlab -.-"
(3,338 Views)
"wt i"   ????
If you are using Matlab, then why did you post your question in a LabVIEW forum?
(3,334 Views)
