yokogawa dl750 scope corder communication
I use Ethernet communication to communicate between Yokogawa DL750 scopecorder and NI-PXI-1042 to save the data to PC using LABVIEW program. However, the problem is that it only saves hdr file to PC and not .wvf file. When ever I click save using LABVIEW program it saves to the oscilloscope. Nothing changed in the program. The only thing changed was, I updated the firmware of DL750. I will appreciate if somebody can please suggest what wrong I am doing here.
(1,627 Views)
So it worked the way you wanted to before, then a firmware update changed how it worked?
This seems like something you ought to contact Yokogawa to find out if it was an intentional change, and if you can override it by changing the commands you use or possibly roll back to an earlier firmware revision if what you want is just impossible now.
Either that, or see if you can set up some sort of file transfer between the scope and your PC and add code to your program to copy it from the scope to your PC.
(1,608 Views)
Can you tell me the firmware version of the DL750
Kees
(1,573 Views)
