yokogawa wt1600 measurements
So I am writing some test automation software with 8.2.1 for the WT1600. I need to sample voltage and amperage on element 1 and 2 (as an example) at ~1hz. I am using the LV newest drivers for it. The setup VIs make sense but I don't see an obvious way to read the elements/channels? The  Read Preset Numeric Normal works OK but what are the presets? I can see some of the info I want but not all of it... Thanks!
Message 1 of 13
(7,616 Views)
you can use the output item function
see the attachments
xufeng,ke@philips,com
Message 2 of 13
(7,610 Views)
Thanks!
Looks like you're configuring then reading the numeric normal. I'll give this a shot.
Thanks again.
Message 3 of 13
(7,587 Views)
Hi,everyone,I have a problem about the connection with the WT1600.The devise can use serial and Ethernet port connect to PC,Now, I want to use Ethernet port,but there is a problem in the initiliaze,I bulide the default inport like this "TCPIP::192.168.0.10::10001::SOCKET",and a error said they can't identify the device.Who can tell me how to solve it?
Thank you very much!
Message 4 of 13
(7,246 Views)
Did you add the device in MAX? Right click on Devices and Interfaces>Create New>VISA TCP/IP Resource. Follow the directions. You should first find out if your instrument is VXI-11 compliant.
Message 5 of 13
(7,240 Views)
Thank you,Dennis.I didn't  add the device in MAX.I will have a try!
Message 6 of 13
(7,234 Views)
I have a similar problem connecting to a WT1600 device.
I have created the VISA device in MAX:
VISA_device_MAX
Now, I'm trying to connect to the device using User's Manual commands:
Where WT1600 is my username, and there is no password needed. I know that I'm connecting to the device because it's answering to the first command with this:
I don't know if is asking for the username, if the username needs a "command" or something, if the way I send the username isn't correct... any clue on this?
Message 7 of 13
(5,834 Views)
I'm not sure what you are trying to do. According to the manual I looked at, the Ethernet port is not used for programming the instrument. Are you trying to use the ftp function?
Message 8 of 13
(5,814 Views)
Hello Dennis,
First of all, many thanks for the prompt reply.
I would like to control the wt1600 by commands, using labVIEW drivers. I though that this could be possible via ethernet, but if you say that is not possible... Have you got any sample program using ftp function?
I have downloaded the trial version of WTViewer and connect it using ethernet and we can see values in "real-time". We have also try to do it using RS232-USB cable, but we could not connect, not with WTViewer, not with labVIEW. I'm getting Error -1073807298 after VISA read. I have used the same RS232-USB adapter with other instruments without any trouble, so I don't know what may happen.
Thanks!
David.
Message 9 of 13
(5,787 Views)
You can use the WT1600 with an Ethernet connection. As a start use the example program Yokogawa provided in the driver package.
Kees
Message 10 of 13
(5,777 Views)
