your program no run
Hello Kalin T
I run your program but it no was correct
please guide me for "reg event callback" function by some hardware example
I can't work by this function correct ant exact
thank you
Message 1 of 10
(5,695 Views)
A forum does not work like this. If you want Kalin to actually see this, you should post this as a reply to the relevant thread.
In general, to find examples, you can search the example finder by going to the Help menu and selecting Find Examples.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
___________________
Try to take over the world!
Message 2 of 10
(5,692 Views)
Hello Kalin T
thank you
Message 3 of 10
(5,673 Views)
(Sight! It is not worth repeating the same text without new information.)
I assume this is about the following thread https://forums.ni.com/t5/LabVIEW/I-get-an-eventoracle-cpp-line-432-error/m-p/455075 but I dont see any program attachment by kalin, just a link to the KB.
I would highly recommend to continue in the original thread. Good luck!
Message 4 of 10
(5,669 Views)
545454,
Please continue posting in the original thread. I left you a message there.
Thank you!
Kalin T.
Message 5 of 10
(5,624 Views)
Hello Kalin T
My problem solved
thank you for help
regard!
Message 6 of 10
(5,590 Views)
545454,
I am glad you were able to figure out the problem. Could you please share the solution with us? I am really curious what you found out.
Kalin T.
Message 7 of 10
(5,558 Views)
Kalin T,
In reg event callback function right click in event source and don't check  "lock panel until handler completes" section
thanks
Message 8 of 10
(5,512 Views)
Hello Kalin T
I want some of data in the callback vi(in reg event callback function) get and display in main vi,
in other message i want to give outputs from this function
can i ?
thank you
Message 9 of 10
(5,510 Views)
545454,
You can do that by using Global variables. You can read more on them here.
Kalin T.
Message 10 of 10
(5,464 Views)
