yule walker
hi
i have to work on the yule walker method and i was wondering if there is anybody who already has the algorithm, or try it in labview
thanks in advance
(2,991 Views)
Hi madgreek,
If you're running LabVIEW 8.0 or 8.2 you can use the MathScript node to execute the aryule() function, which uses the Yule-Walker method to estimate autoregressive (AR) model parameters.
Here is more information on this command"
aryule (MathScript Function)
Michael K. | Applications Engineer | National Instruments
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
(2,958 Views)
