z^n-1 delay
Very sorry,i was wrong.
3Phase PLL is not the right one.
I do have soft motion and fpga installed and targeted properly
Message 11 of 12
(952 Views)
Ah! It looks like those VIs are not part of LabVIEW or toolkit OR they are old implementation of it and cannot be found in actual version of LabVIEW.
For example, one of your VIs looks like this:
http://zone.ni.com/reference/en-XX/help/371093G-01/nismlvhlp/control_loop/
This was substituted by this:
http://zone.ni.com/reference/en-XX/help/371093M-01/nimclvfb/controlip.pid.motorcontrol_00b20003/
and the other VI looks like this:
https://forums.ni.com/t5/LabVIEW/LabVIEW-2015-FPGA-where-did-the-fixed-point-PID-go/td-p/3191736
If I recall, this document is part of this community:
https://forums.ni.com/t5/Power-Electronics-Development/bd-p/grp-1891
I would suggest looking around this community for the most up to date document with those VIs available. Also, if you are able to find the original VIs from the document, you probably should be able to open those in the new version of LabVIEW. In general, the VIs will be able to be opened, but it just not in the palette.
Barp - Control, Simulation, RTT and HIL - National Instruments
Message 12 of 12
(934 Views)
