zaber stage speed settings
Hi, I am using some Zaber stages and want to be able to let the user adjust the speed of the stages but can't find a clear way of how to adjust their speed.  Any help on the matter would be great thanks!
(1,788 Views)
Accepted by topic author mhg_v
Are you using the ZaberASeries library? Within the Configure folder of this library is a "Set Speed and Acceleration" subVI that will allow you to adjust the speed. The speed setting is non-volatile; after you set it, it will persist until changed.
Mike McDonald
mike@zaber.com
(1,775 Views)
Have you tried their LabVIEW driver?
https://www.zaber.com/software
George Zou
(1,771 Views)
When I browse the Zaber Library I only get examples for other use in other programming systems
(1,753 Views)
