zero iteration for loop
Hi folks,
There's an old behavior that I'm pretty used to, but it still occasionally bites me (usually with references).  It happened again today, and it got me to wondering if it's really intended behavior.
If you pass a value into a zero iteration for loop, then send it out the other side, the value exiting the for loop is returned to default, not the value you fed in (see simple.vi, LV7.1).
Any ideas?
Joe Z.
(5,928 Views)
This is expected behavior...the workaround is to use shift registers to pass the value through instead of tunnels.  I believe this is discussed in the LabVIEW Help.
-D
(5,922 Views)
Thanks Darren, it's right there in the help.
It puts me in a bit of a quandry, since I've seen some odd behaviors when I put things like queue references into shift registers.
Ah, well, we've all managed this far.
Thanks again,
Joe Z.
(5,918 Views)
