zlib inflate OpenG Error
I've just replaced the "Zlib Inflate" and "Zlib Deflate" VI's that come with blowfish algorithm with that of OpenG versions, and it provides a generic error if the "Compress Before Encryption" button isn't pressed. If I compress the data however it all works.
Attached contains a "Test.vi" for testing purposes.
I'm hoping someone can let me know whats happenning.
(3,272 Views)
Never mind. Issue solved. I didn't look too closely on the originan blowfish algorithm.
Kas
(3,269 Views)
