zoom en waveform
Hola,
Estoy realizando un proyecto en Labview v8.0 y estoy trabajando con una Waveform en la que me interesaría poder aplicarle un zoom en una zona que el usuario deseara, lo que no se es como hacerlo, ¿alguien me puede ayudar?
Muchas gracias,
G.R
(3,136 Views)
Guillermo,
Sorry, I don't speak Spanish.  Any chance you (or anyone else) can translate into English?  (You'll probably get help faster that way).
-Matt
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,135 Views)
Yes...sorry if my English is not very good. What I'm trying to explain is that I'm doing a proyect were I work with a waveform and it would be useful if I could do a zoom in the place where the user prefers, so that the user could see better the zone of the waveform he is interested in. If you or anyone could help me I would be very grateful.
G.R.
(3,120 Views)
Accepted by topic author Guillermo_Rigal
Right click on the graph in the visible item enable the graph pallette, Using this user can zoom the the waveform in the required manner.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,112 Views)
