zoom fft fpga
Hi everybody,
i have some general questions about FFT on FPGA's and the frequency resolution in spectral analysis.
To establish understanding:
i want to read a frequency with fs = 500kS on my FPGA. The FFT function from the FPGA palette allows a maximum of N = 8192 samples. This results in a frequency resolution of  fs/N = 500.000/8192 = 61,035Hz    and a frequency range of fs/2 = 250.000Hz.
My destination in the spectral analysis is a resolution of 1Hz in the range from 9kHz to 11kHz.
My questions:
1. Is there a similar function for FPGA applications like the "Zoom FFT" in the Sound and Vibration toolkit or can i use it on FPGA target-VI?
2. Is there any existing example code for an other "overlap and add" or "overlap and save"- method for Fourier Transformations on FPGA?
3. Any other suggestions for the described problem?
Best regards and
thanks in advance
Sebeck
(3,768 Views)
Accepted by topic author sebeck
Hi sebeck,
The result of your calculation is correct, you get a frequency resolution of about 60Hz, but the way you calculated it is wrong. If you sample with 500kS/s you can have a maximum frequency of 250kHz and from the FFT you will have 8192 lines in your spectrum, so theoretical you would have a resolution of about 30Hz. But the FFT at the FPGA is both-sided, so it returns positiv and negativ frequencies. You cannot use the negaive ones, so you have only 4096 lines left from which you get a frequency resolution of about 60Hz.
That being said there is no Zoom FFT for FPGA and you cannot use the Express VI from Sound&Vibration TK there.
So if you need the frequencies up to 11kHz, you could decimate the data and sample with 22Ks/s, then you get a resolution from 2.7Hz.
With a fixed blocksize you can only get a better frequency resolution in measureing a longer time.
Hope this helps,
Christian
(3,739 Views)
