zoom fit
I have a Chart graph as follows, to display waveforms and uses abslute timestamp as the x scale.
But When I use palette tool of "Zoom to fit" , I always get this weird scale on X that the chart begin from 01:00:00 to display.
not the beginning of the waveform.
What should I do to solve this?
Thank you.
(3,554 Views)
Hi Wang,
remove any points from your plot with an X value of zero…
Please show the full VI with some example data set as default!
(3,544 Views)
Actually, there is no special treatment on the graph chart, I just want to make a proper zoom scale on time axis at first run.
Thanks a lot!
(3,503 Views)
I try to copy the chart control to this vi.
How can I add it as a attachment?
(3,499 Views)
Hi Wang,
there's an "Attachments" line below the message edit box.
When you have problems to attach VI files you can either ZIP them or rename them to "*.vit"…
(3,496 Views)
