zoom in/out of block diagram
at the moment I am working with a huge
block diagram. It is a bit difficult,
to keep the overview over the whole block diagram
by scrolling.
Is there any possibility of Labview to zoom out of the
block diagram?
Any other solution?
I could find one in the internet.
Thank you very much for your help.
Hannes
Message 1 of 11
(4,553 Views)
Hannes;
Check out the Bird's Eye View Utility at OpenG.org
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
Message 2 of 11
(4,551 Views)
Hannes Hapke wrote:
> Hi,
> by scrolling.
> block diagram?
LabVIEW 7.1 has this built in.
> Any other solution?
So why do you ask :-). Or did you mean you couldn't find one? I believe
there is something on lava usergroup, www.lavausergroup.org
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 3 of 11
(4,551 Views)
sorry for my mistake. I counld not find one in the
internet.
Thank you for the posting about Birds Eye View.
But how does it work?
Should I have to open it first and then I can open
the other VI with BEV?
regards,
Hannes
Message 4 of 11
(4,551 Views)
Just download and play with the tool. The tool detects the VIs currently in memory, and you can select the one you want to see in the control that reads "VIs in Mem". Because you have access to the source code, you can review it to learn the nuts and bolts on how it works!
The author, PJM LabVIEW, has put a lot of effort in this excellent tool and I am sure he will be more than happy to answer any questions you may have (and even add new features you request, of course, if they are valuable and can be implemented)
www.vartortech.com
Message 5 of 11
(4,551 Views)
I certainly would do that 🙂
vipm.io | jki.net
Message 6 of 11
(4,551 Views)
thanks 1000-times!!!!!!!!!!!!!! 🙂
It works.
I just open the Birds eye View first and I could not load
any other VIs. But now I understood to load the VI first and
then to open the BEV.
Thanks again.
Hannes
Message 7 of 11
(4,551 Views)
Hi Hannes,
>I understood to load the VI first and then to open the BEV.
Actually, you can open the BEV first, and if you have nothing else in memory, you can browse to a VI using the VI path control (next to the VIs in Mem text ring). You can also load VIs after having opened the BEV. It will refresh the VIs list in memory (text ring) every two seconds. Click the help button (upper right corner a button that look like this -> [?]) for more description about the BEV functionality.
Cheers
PJM
vipm.io | jki.net
Message 8 of 11
(4,551 Views)
If LV7.1 has this built in, how is it accessed?
Message 9 of 11
(4,551 Views)
menu: "window... show navigation window"
(or Ctrl+shift+N)
Message 10 of 11
(4,551 Views)
