zoom video
Hi all
I want to know if we can zoom a video file in Labview?At present i'm playing a video file through  acive X control and is trying to find a wy to zoom the video
(3,638 Views)
You are using the activeX control so find out if the activeX functions provides the options(property/invoke nodes) such as zoom % to zoom the video within the activex control. The zoom property must be provided by the activex control itself and cannot be done exploited using LabVIEW funtions.
Hope this helps.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,636 Views)
I can not find any zoom property in ActiveX invoke or property node.
Haresh D. Patel (M-9913678668)
Engineer, IPR Ganghinagar
(3,025 Views)
Hi Harry,
as has been written 10 years ago:
Which ActiveX control are you using?
(3,020 Views)
