As labview has them for ever, can you add them to CVI helping reduce the UIR handling and programming a bit?
Can you post a picture so that people not using LabVIEW know what you're suggesting? Or do you mean to combine any switch available already now with any LED (this would result in quite some combinations...), while saving one line of code?
the silver pack or the modern pack give a nice touch
Ah, thank you! Would you agree that these are the same buttons as depicted here ?
well yes, with the addition of the boolean swiches...
