LabWindows/CVI Idea Exchange
Andre_Saller
Autoscale with offset for the graphs
IF autoscaling is activated for graphs on the UIR, it will fit the scale exactly to the data displayed. I would like to have an option to add an offset, so that the scale is always a little bit "bigger" then the data plotted.
For example if there would be an option "Autoscale Offset: 10", and I would plot an array containing data with values of min 30; max 340, the autoscale would set the scale to min 20 and max 350.
2 Comments
LuisG
NI Employee (retired)
Status changed to: Completed
This feature already exists. Look at the "Loose Fit" (ATTR_YLOOSE_FIT_AUTOSCALING) and "Loose Fit Units" (ATTR_YLOOSE_FIT_AUTOSCALING_UNIT) settings.
LuisG
Status changed to: Already Implemented
