LabWindows/CVI Idea Exchange
FoxSquirrel
Block Comments
Status: Completed
Hi FoxSquirrel,
Thank you for your idea submission. We have added this feature in the most recent version of LabWindows/CVI, LabWindows/CVI 2017. Feel free to check it out here: https://www.ni.com/en/support/downloads/software-products/download.labwindows-cvi.html#306969
Collin
Allow you to select multiple lines and then go to Edit>>Block Comment/Uncomment to be able to comment or uncomment multiple sections of code at once.
Jesse S.
5 Comments
vix
Active Participant
Active Participant
You can do that with a workaround:
  1. select the lines and press CTRL+E (Edit >> Toggle Exclusion)
  2. select Edit >> Resolve all Excluded Lines
  3. press "Comment" (or "#if 0" if you like)
Vix
Using LV from 7
Using LW/CVI from 6.0
Wolfgang
Trusted Enthusiast
I did discover this feature but still kudoed the idea because it would allow using a shortcut, i.e. one keystroke only
JonathanN
NI Employee (retired)
Status changed to: Under Consideration
Jonathan N.
TheNIDragon
Status changed to: In Development
Hi FoxSquirrel,
Thank you for your post. We are moving forward with development of this feature. It should be included in the next available release of LabWindows/CVI.
Collin Draughon
LabWindows/CVI Product Manager
Collin D.
Software Product Manager
TheNIDragon
Status changed to: Completed
Hi FoxSquirrel,
Collin
Collin D.
