LabWindows/CVI Idea Exchange
ciaoa
Correct interpreting control characters in Textbox
Status: New
The Textbox (until CVI2010) interprets the control characters not correctly. The only control character, which is correctly interpreted is "Line Feed" (LF, "\n"). "Carriage Return" (CR, "\r") for example, is also interpreted as "Line Feed" (LF). Other control characters like "DEL", "Back Space" etc. are not interpreted. TAB ("\t") is interpreted, so far I know. Is it possible that the Textbox interprets the control characters correctly? This would make the use of the function "SetCtrlVal(...)" very good.
