LabWindows/CVI Idea Exchange
RobertoBozzolo
Correctly show control on a tab page when coming from source code
Status: New
While editing the code, pressing Ctrl+Shift+U or selecting Right-Click+Find UI object jumps directly to the object identified in the code (either the control constant name or the associated callback name).
This works well if the control is on a single panel: the correct panel is shown in the working area of the editor scrolling through the file if needed. If the target control is on page of a tab control, however, the UIR editor opens in the upper left corner of the UIR file; actually the correct control is selected on the tab page, but if it is located out of the editor screen area in the UIR file you need to manually scroll right- and/or downward to show it.
Please correct it: it's not always obvious where the target control is located in the UIR file, wespecially if this one is rather complex, with several panels/controls.
1 Comment
LuisG
NI Employee (retired)
I think this should actually be considered a bug. It's being tracked with ID 488375.
