Hello NI,
during program development and debugging typically there is more than just the source window visible, i.e. the lower part of the screen is used by the find or the build output window. Now, if I switch to a different tab/window to edit the UIR file, this build output window will still be there and take valuable space, although it is completely useless for editing the UI. If I close it, it will remain closed even if I switch back to the source code.
I would prefer that 'context sensitive' wndows such as 'find results' / 'build output' ... only show up if meaningful, while they are automatically hidden if not needed, i.e. when a UIR window is displayed, and automatically redisplayed if the source code window is back.
Thanks for possible consideration,
Wolfgang
