In CVI 2013 the array display has changed (for the worse, in my opinion).
There are two minor inconveniences and one acute shortage I would like to see improved (hopefully prior to CVI2020
First, the right click context menu: If I want to see values of a numerical array, it offers a 'Graphical Array View' but no 'Array View', so one first has to chose 'View Variable Value' and then 'Array Display' - maybe one could save one step and already provide the 'Array Display' in the first case...?
Second, the new Array View table still is very slow, not extremely slow as prior to SP1 but still very slow...
Most importantly, at present it is impossible to debug large arrays, large meaning arrays with more than 10000 elements. The current implementation requires to select a slice of data - but this makes it impossible to check or compare say array indices 5, 10005, and 20005...
Of course I agree that there is no need to simultaneously see more than 10000 data values - but why not have a table with say 100 rows that can be turned over, e.g. displaying either elements 1-100, 101-200, ... this way one could access and inspect all array values...
