In the "Select UIR Constant" dialog box that pops up when the "..." button is pressed for functions that deal with the UIR such as SetCtrlVal(...), in would be nice if the list control that lists the available UIR files was made larger. Right now there are only four lines visible, which means in projects with a lot of UIR files I need to do a lot of scrolling and hunting around. Thanks.
