In few applications, while plotting multiple parameters on same graph,we should have multiple Y-axis insertion.
Like 1 parameter's axis limit is 0 to 50 while other has 0 to 5000 ,so when we plot both ,the change in parameter with smaller value is not seen properly.it look like plain line.
Also when we move cursor to graph it should show value at that position.
