I'd like to suggest another command strengthening the table control: Because tables can be used also for documentation, it would be helpful to ease the printout of table controls by a dedicated command.
The PrintTable command should not print scrollbars, and it should include
- two integer attributes for the number of columns/rows that shall be printed per page
- a boolean attribute indicating if tables too large to fit on a page are split first horizontally or first vertically
- an integer attribute specifying the font size
- a boolean attribute if the header shall be repeated on subsequent pages
- a boolean attribute if the frame lines are printed or not
- two boolean attributes if the vertical/horizontal grid lines are printed
- an integer attribute specifying the thickness of the frame lines
- the option to generate graphic files (png, jpg): if several pages would be printed this should result in several graphic files
Right now these goals can be achieved only by creating a second, hidden table control with the requested attributes which is then filled programmatically.
