 ngay528
			 on
		12-09-2010
		03:49 PM
			1 Comment (1 New)
			ngay528
			 on
		12-09-2010
		03:49 PM
			1 Comment (1 New)
		Not sure if any other IDEs use this, but it would be nice to select an option toif when cut and pasting code to somewhere else in the file, is if the indentation corrected itself.
So instead of absolute indentation from where it was at previously (column number from line), it would be relative indentation based on the first line cut/copy and pasted.
