Most user settings are kept in either the project or the workspace file. Unfortunately, this is not true for building a function tree (Options/Generate Function Tree). Starting CVI the previous entries are lost. Actually this is an old issue but may be not too old to be improved... ![]()
So I suggest to save the information about Instrument name, Function prefix, Default qualifier, and Output function tree in the appropriate configuration file (prj or cws)
Thanks ![]()
