I just discovered a strange and unexpected behavior of EVENT_VAL_CHANGED which requires that I will have to double check all my previous software written in CVI...
For some reason I have assumed that if the EVENT_VAL_CHANGED is triggered on a numeric control the new value will be different from the old one. This may not be true - the value may be still the same!
Since for more experienced users this seems to be a well-known fact I doubt that NI will call it a bug, hence I am suggesting an improved behavior
: Please, for numeric controls, fire the EVENT_VAL_CHANGED event only if the numeric value has changed...
(Right now, if the numeric control displays 1.0000 and I enter '1 ENTER' the value remains the same (at least), but the EVENT_VAL_CHANGED event is triggered...)
PS: Also the documentation seems to be misleading: It (in CVI2010) states:
The EVENT_VAL_CHANGED event is generated continuously while the user is performing an ongoing action which results in the value of a control changing.
