when using the two subwindows of the source code editor I frequently need to scroll both windows the same way because my screen isn't high enough
This means that I scroll down one window, switch to the other window, and scroll again.
It would be much more convenient having the possibility of simultaneously scrolling both windows. I imagine that pressing the SHIFT key modifier would allow for synchronously scrolling both windows while scrolling without the SHIFT key would show the present behavior.
What do you think? I think it's no big deal of implementing it
