First of all : I LOVE the Format File and Format Selection and many thanks for the existing options in the dialog box (pointer for example)
Here is what I propose :
1 - "Function calls on single line" check box in the Miscellenaous section of the dialog box so that :
int CVICALLBACK ScaleIt (int panel, int control, int event, void *callbackData,
int eventData1, int eventData2)
int val;
if (event == EVENT_COMMIT)
GetCtrlVal (panel, control, &val);
SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_ACTIVE_YAXIS,
VAL_RIGHT_YAXIS);
SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_YMAP_MODE, val);
SetActiveCtrl (panel, PANEL_GRAPH);
return 0;
The code above comes from ..\CVI2013\samples\userint\2yaxis.prj
Is transformed in :
int CVICALLBACK ScaleIt (int panel, int control, int event, void *callbackData, int eventData1, int eventData2)
int val;
SetCtrlAttribute (panel, PANEL_GRAPH, ATTR_ACTIVE_YAXIS, VAL_RIGHT_YAXIS);
return 0;
Please note this apply not only to the SetCtrlAttribute() function call but also to the ScaleIt() function itself (very first line)
A long time ago it was OK to restrict ourselves to 80 chars per line but today I feel more confortable with statements on one line
2 - "Insert empty line before first statement in function definition" check box in the Miscellenaous section of the dialog box
Especially usefull when you use the Java Formating Option where the '{' is at the end of the line
With the previous sample code :
int val;
return 0;
The formated source (Java) should be :
int CVICALLBACK ScaleIt (int panel, int control, int event, void *callbackData, int eventData1, int eventData2) {
int val;
if (event == EVENT_COMMIT) {
return 0;
Instead of :
int val;
return 0;
Pay attention to the "int val;" declaration with one spacing line in the first code and no spacing line in the second one.
Best regards, Philippe
