watch expressions support the possibility to monitor changes of variables by placing the variable in the watch window. Unfortunately, at present it seems impossible to put a 2 D variable in the watch window, e.g., x_data [ 2 ] [ 3 ].
The new idea is to allow this ![]()
Thanks!
