Is there a configuration/source management system available for LabWindows/CVI? If not, one is desperately needed.
CVI already integrates with various third-party source code control software packages. Is this what you're referring to?
Which ones? Is there a list somewhere?
This page lists several packages that have been tested with CVI at some point. However, CVI should support any package that implements the MSSCCI plug-in interface.
For more CVI-related documentation, start with this topic.
Luis
